Page 1 of 2
WTB: shifter-trans linkage from 11-13 car
Posted: Thu Jul 11, 2019 1:13 pm
by Ilikemtb999
Looking for the shifter arm and rod on the side of the transmission to the shifter from an 11-13. I’m doing a console swap on a 14 that has the column shift.
Re: WTB: shifter-trans linkage from 11-13 car
Posted: Thu Jul 11, 2019 1:22 pm
by lastcall190
Can't help with the parts but if you can't find them used, new they don't look too expensive:
There's the diagram (thanks Steve!)
Part #1 looks like what you'd need, no? If you need the actual shifter, I will probably have one when I swap consoles.
Posted: Thu Jul 11, 2019 1:32 pm
by Ilikemtb999
Yep that’s what I’m looking for! I cannot find that on gmpartsdirect. Do you happen to have the part number? Thanks so much!
Posted: Thu Jul 11, 2019 1:37 pm
by lastcall190
Crap I left out the P/N legend:
92254927 and 92254928 are both listed as Part #1, ~38 and 19 dollars respectively. I have NO idea what the difference is unfortunately.
https://chevrolet.7zap.com/en/caprice/4 ... 27734-0-0/
Posted: Thu Jul 11, 2019 1:52 pm
by Ilikemtb999
Thanks I forgot about that site.
I’d almost prefer used if I can get it just so I know what I’m actually buying. I’ve seen the 9c1 ones used without issue. With shipping that cheaper one is like $28 though.....
Posted: Fri Jul 12, 2019 10:57 am
not sure what this # 92254927 is for , but it doesnt come up
92254928 , shows for the 11-13
92191383 is the trunnion #3 in the diagram
Posted: Fri Jul 12, 2019 11:36 am
by lastcall190
Thx for clarifying... at least it's the expensive one that doens't show up :lol:
Posted: Fri Jul 12, 2019 1:31 pm
by RM96
I did the SS dash, cluster, console, shifter & steering wheel swap on my 2016
I ordered the following SS parts from GMPD
GM part # 92259754 - Rod
GM part # 92191383 - Shifter Trunnion
GM part # 92191384 - Shifter Bushing
GM part # 92139143 - Lift Cylinder Bolt
Posted: Fri Jul 12, 2019 3:30 pm
by Ilikemtb999
RM96 wrote: Fri Jul 12, 2019 1:31 pm I did the SS dash, cluster, console, shifter & steering wheel swap on my 2016
Thank you! Does the rod include the portion that mounts to the trans or is one of the other pieces the part that does that? The shifter I have has the bushing and the piece the rod slides into and then the bolt holds it down.
Posted: Fri Jul 12, 2019 6:44 pm
by RM96
Correct, the rod and linkage to the trans are one part. Comes just like #1 in the diagram posted above.
