WTB: shifter-trans linkage from 11-13 car
If you're looking for a specific Caprice PPV-related part, service, or car post your requests here.
Ilikemtb999
Post by Ilikemtb999 » Thu Jul 11, 2019 6:13 pm
Looking for the shifter arm and rod on the side of the transmission to the shifter from an 11-13. I’m doing a console swap on a 14 that has the column shift.
lastcall190
Re: WTB: shifter-trans linkage from 11-13 car
Post by lastcall190 » Thu Jul 11, 2019 6:22 pm
Can't help with the parts but if you can't find them used, new they don't look too expensive:
There's the diagram (thanks Steve!)
Part #1 looks like what you'd need, no? If you need the actual shifter, I will probably have one when I swap consoles.
!DOD : LS9 Cam : Pat G : Magnaflow : VCM
172k and going strong... Nearing retirement
Ilikemtb999
Post by Ilikemtb999 » Thu Jul 11, 2019 6:32 pm
Yep that’s what I’m looking for! I cannot find that on gmpartsdirect. Do you happen to have the part number? Thanks so much!
lastcall190
Post by lastcall190 » Thu Jul 11, 2019 6:37 pm
Crap I left out the P/N legend:
92254927 and 92254928 are both listed as Part #1, ~38 and 19 dollars respectively. I have NO idea what the difference is unfortunately.
https://chevrolet.7zap.com/en/caprice/4 ... 27734-0-0/
Ilikemtb999
Post by Ilikemtb999 » Thu Jul 11, 2019 6:52 pm
Thanks I forgot about that site.
I’d almost prefer used if I can get it just so I know what I’m actually buying. I’ve seen the 9c1 ones used without issue. With shipping that cheaper one is like $28 though.....
Post by s/c'd cav » Fri Jul 12, 2019 3:57 pm
not sure what this # 92254927 is for , but it doesnt come up
92254928 , shows for the 11-13
92191383 is the trunnion #3 in the diagram
lastcall190
Post by lastcall190 » Fri Jul 12, 2019 4:36 pm
Thx for clarifying... at least it's the expensive one that doens't show up :lol:
RM96
Post by RM96 » Fri Jul 12, 2019 6:31 pm
I did the SS dash, cluster, console, shifter & steering wheel swap on my 2016
I ordered the following SS parts from GMPD
GM part # 92259754 - Rod
GM part # 92191383 - Shifter Trunnion
GM part # 92191384 - Shifter Bushing
GM part # 92139143 - Lift Cylinder Bolt
Ilikemtb999
Post by Ilikemtb999 » Fri Jul 12, 2019 8:30 pm
Thank you! Does the rod include the portion that mounts to the trans or is one of the other pieces the part that does that? The shifter I have has the bushing and the piece the rod slides into and then the bolt holds it down.
RM96
Post by RM96 » Fri Jul 12, 2019 11:44 pm
Correct, the rod and linkage to the trans are one part. Comes just like #1 in the diagram posted above.
