It is currently Sun Jun 24, 2018 1:47 pm
Post new topic Reply to topic  [ 6 posts ]
Author Message
 Post subject: Transmission Cooler
PostPosted: Thu Aug 31, 2017 12:31 am
Offline
Looking for a factory transmission cooler closer to Nc the better or I can pay for shipping either way. if I do not find one soon I'll just install a aftermarket
Top
 Profile
 Post subject: Re: Transmission Cooler
PostPosted: Thu Aug 31, 2017 3:55 am
Offline
The largest B&M cooler is only about $130 and cools a lot better than the factory cooler. It keeps mine between 170 and 200 degrees with a 3800 converter on 90+ degree days while hammering on it pretty much constantly. Mine is still plumbed through the radiator. Temps might actually go lower if I bypass it.
Top
 Profile
PostPosted: Thu Aug 31, 2017 10:18 am
Offline
I don't suggest bypassing the in-rad cooler. It helps regulate the trans fluid temps. The sweet spot for transmission fluid on a street driven car is about 180 degrees. External coolers that are not in series with the in-rad cooler can over-cool the fluid, especially in cold climates.
_________________
Tom (AKA: Storm)
2011 Caprice 9C3: L77, 7K miles, first-owner, purchased July 2011.
1995 Caprice 9C1: LT1, 176K miles, summer car.
1995 Impala SS: LT1, 20K miles.
1995 Caprice Wagon: LT1, 61K miles.
1994 Caprice 9C1: LT1, 101K miles, winter car.
1972 Chrysler Newport: 400ci big block, 27K miles, 2-door hardtop.
Top
 Profile
PostPosted: Thu Aug 31, 2017 2:34 pm
Offline
It all depends on the car and its intended usage. In a cold climate, you would probably never want to bypass the radiator. In that case, it actually acts as a fluid heater. For a car with a 3800 converter and close to 500 whp driven in the summer, I doubt there would be a problem. This is a highly debated topic with no right or wrong answer. There are way too many variables between vehicles, climate, usage, etc. The only way to know is to try.
Top
 Profile
PostPosted: Fri Sep 01, 2017 9:11 pm
Offline
I am going to go aftermarket, it's a $140 for a factory cooler and I can get a better trans cooler for less money. My car had a factory mounted transmission cooler
Top
 Profile
PostPosted: Fri Sep 01, 2017 11:11 pm
Offline
The lower intake area has a huge area and easy mounting to the actual metal frame crossmember. This keeps it out of the large intake which can be used for a OTR air intake and also means you don't see it as easily.. The factory lines won't just bolt up to that but its not much work to make it happen.
Top
 Profile
Search for:
Jump to:
