It is currently Sun May 27, 2018 4:26 am
Post new topic Reply to topic  [ 13 posts ]  Go to page 1, 2  Next
Author Message
PostPosted: Thu Jun 15, 2017 10:39 pm
Offline
Looking for the passenger rear window harness and switch for a 2012 caprice Ppv mine is corroded and they are 75 $ for the harness from gm
Top
 Profile
PostPosted: Thu Jun 15, 2017 11:57 pm
Offline
Where did it corrode? A the main connector? If at the main connector I have those terminals I could make you up a pigtail with some butt connectors to attach to the rest of the harness.
_________________
Top
 Profile
PostPosted: Sun Jun 18, 2017 2:34 am
Offline
It is corroded where it plugs into the switch there was glass in the bottom of the back door so I'm guessing the window got broken and it rained and wrecked the switch and harness. And I can't find where to buy a pin kit to redo the harness
Top
 Profile
PostPosted: Sun Jun 18, 2017 3:15 am
Offline
Some searching shows that is Yazaki 090-II series connectors and terminals.
If you need a new connector that is Yazaki 7283-1060
The terminals you would need (5 of them) is Yazaki 7116-4022
I have some if these already I can make you up 5 pigtail wires if you can reuse your connector. Then you can just butt connector them down the harness a bit and stagger the connectors to make the harness thinner. Send me your address if you want to go that route.
As for the switch have you popped off the back? May a bit of clean up could save the board and contacts. If anything that is where I would spend my money and get a new one. $26 bucks ain't a lot for new.
_________________
Top
 Profile
PostPosted: Sun Jun 18, 2017 4:20 am
Offline
I appreciate it I'm gonna pull the door panel apart tomorrow and see if the harness is worth saving and if I can go that route I will send you my address. And that was my thoughts exactly on just buying the new switch
Top
 Profile
PostPosted: Sun Jun 18, 2017 11:11 pm
Offline
Here's a pic it looks like the connector is still good just needs to be re pinned
Top
 Profile
PostPosted: Mon Jun 19, 2017 1:35 am
Offline
Yea that looks pretty bad.
I will work on some wires tonight.
_________________
Top
 Profile
PostPosted: Mon Jun 19, 2017 4:24 am
Offline
Thanks appreciate it here's 1 more pic
Top
 Profile
PostPosted: Fri Jun 23, 2017 4:14 pm
Offline
System Manager
Two extremely oversize pictures have been moderated. Please downsize your pictures when posting to conform to our guidelines or the zap gun comes out again!
_________________
System Manager and your tourguide for the day. Caprice Alumni, former owner of a 2011 Caprice 9C3 with a Rotofab CAI and front radiator cover, 3.45 LSD Camaro rear diff, Chris Henry performance tune, G8 GT 18" Enkei rims w/Holden lions, custom SLP axle-back muffler set with tips, Holden WM Caprice factory spoiler, Holden SSV leather steering wheel and leather shift knob, Whelen Alpha-12Q airhorn amp. G8 GT rear seat swap, AVS Ventshades.
Top
 Profile
PostPosted: Mon Jun 26, 2017 1:20 am
Offline
Thanks again Steve I got the wires and re pinned the plug only stabbed my self in the fingers 2 times in the process. Not sure if it works yet because the motor is still out and I can't hook up the battery to test it but I will keep you posted
Top
 Profile
Search for:
Jump to:
